PC386 BSP vs. paranoia
Eric Norum
eric.norum at usask.ca
Thu Apr 26 14:34:56 UTC 2001
Angelo Fraietta wrote:
> Which RTEMS snapshots are Build tools are you using ?
> Eric Norum wrote:
> > I'm new to the RTEMS/PC world and I'm having troubles. The latest
> > problem is that paranoia does not seem to run properly on my 486-DX2/66
> > target (pc386 BSP). I get a couple of `FAILURE' messages (they scroll
> > by awfully quickly) and then it locks up after printing:
> > Testing X^((X + 1) / (X - 1)) vs. exp(2) = 7.38905609893065041e+00 as X
> > -> 1.
> > Is there some code to set up the floating point mode that's missing from
> > the BSP?
Following up my own posting.
It turns out that the problem seems to be related to the compiler. When
I run the non-optimized version of paranoia on RTEMS it completes and
reports a single DEFECT (just like on Linux). Interestingly enough,
when I run the optimized (-O4) version on Linux it locks up in exactly
the same place as does the optimized version on RTEMS.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
