termios problem or feature?
Mike Siers
mikes at poliac.com
Mon Aug 13 20:48:57 UTC 2001
Hi,
I am using the latest RTEMS snapshot with the i386/pc586 BSP.
I have a simple program that is just opening up a serial port and
writing out a string. The application on the other end of the serial
port will write out a block of information to the serial port when it
receives this initial string.
I have noticed that the read() function call will only return one
character at a time even though I know the termios buffer has
more information than that.
Basically, the function fillBufferQueue() in libc/termios.c returns
as soon as it has copied VMIN characters. Should it instead
copy all available characters that will fit into the given buffer?
Is this a bug or is termios behaving correctly?
I have a simple patch to allow it return more than VMIN characters
but I want to ensure this is the correct behavior.
Thanks
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010813/4b7fdcce/attachment.html>
