PC-104
Joel Sherrill joel at OARcorp.com
Fri Aug 17 21:42:34 UTC 2001
rwas wrote:
> I'm using rtems with pc104. I am rather green on rtems however. I have
> successfully compiled and run
> two of the netdemos and hello world. My current problem is that rtems
> won't use the serial port as the
> console device.
My understanding was that you modified the setting of a couple of
variables in
pc386/console/console.c to accomplish this.
* Possible value for console input/output :
*      BSP_CONSOLE_PORT_CONSOLE
*      BSP_UART_COM1
*      BSP_UART_COM2
* Note:
*   1. Currently BSPPrintkPort, cannot be assigned to COM2,
*      it will be fixed soon.
*   2. If both BSPConsolePort and BSPPrintkport are assigned
*      to same serial device it does not work that great
int BSPConsolePort = BSP_CONSOLE_PORT_CONSOLE;
int BSPPrintkPort  = BSP_CONSOLE_PORT_CONSOLE;
/* int BSPConsolePort = BSP_UART_COM2;  */
int BSPBaseBaud    = 115200;
> My processor board is the Jumptec MOPS/586..
> My main issues currently are getting or writing a device driver for
> ethernet chipset (Crystal CS8900)
It has a libchip driver so all you should need is the glue to the
particular configuration.
Chris Johns <ccj at acm.org> submitted this a while back.
> and drivers for a DtoA board as well as a Synchronous Serial Interface
> board.
OK those aren't in the tree.  If they are for off-the-shelf boards, we
all would be happy to see
them in the tree.
And I hope it goes without saying that custom driver development is one
of OAR's
many RTEMS related services.
> Robert Wasierski
> Dynacs Engineering
> Eric Norum wrote:
>> I apologize in advance if this is a FAQ, but is anyone out there in
>> RTEMS-land using PC-104 SBC's?
>> If so, with what processor?  Using what BSP?
>> Thanks,
>> Eric Norum                                 eric.norum at usask.ca
>> Department of Electrical Engineering       Phone: (306) 966-5394
>> University of Saskatchewan                 FAX:   (306) 966-5407
>> Saskatoon, Canada.
> _________________________________________________________
> Do You Yahoo!?
> Get your free @yahoo.com address at http://mail.yahoo.com
