gdb and bdm for RTEMS
John S. Gwynne jsg at jsgpc.mrcday.com
Fri Aug 31 16:52:00 UTC 2001
| 	I also tried gdb-4.18-bdm-patches-pi1.tar.gz, I compiled the driver, an
| d
| patched and compiled gdb. The driver loads, gdb starts, but when I try
| "target bdm /dev/pd_bdm0" , gdb returns:
| Error: BDM device driver version conflict.
|         you need at least version 2, currently installed is version 1.
|         Aborting operation
As I recall, a change in the file operation struct of the later
kernels caused this error. You can modify the module (bdm.o) to fix
this, but I would recommend that you switch to gdb-5.0 instead.
http://cmp.felk.cvut.cz/~pisa/m683xx/gdb-5.0-bdm-patches-pi2.tar.gz
I try to keep my web page (http://www.donet.com/~jsg) up to date with
this type of information, but I have not had time to do so recently.
Also, I have exchanged email with Pavel concerning flash write
capabilities for the efi332 target from within gdb-5.0. I have a
working version, but I don't believe the latest release works yet
out-of-the-box. I will put the details on my web page as time permits....
john gwynne
                                John S Gwynne, PhD.
Mission Research Corporation    Email: jgwynne at mrcday.com
3975 Research Blvd              Tel: (937) 429-9261 x166
Dayton Ohio 45430-2625          Fax: (937) 320-2562
