RTEMS gdb
VALETTE Eric valette at crf.canon.fr
Thu Dec 6 08:41:19 UTC 2001
Stephen Holford wrote:
> Eric,
> I'm curious, what effect do you get by not having the patch?
> After all connect_rdbg_exception is called from within TgtAttach just before
> all of the debugging tasks and semapores are created. FYI, the "FADS" bsp
> I'm using is a quick mod of the mbx bsp from the 20011025 snapshot so my
> environment should be pretty similar to your MBX860 one. I'll send my rdbg
> changes with explanations your way in the next day or so.
> Steve
If you call enterRgdb() from debuggee program before attach, then you
are dead... This is waht happened here. Besides I think the doc still
states that you should call enterRgdb while attach is working...
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
