TCP/IP Stack issue
Gerke Kok gerke.kok at tpa-nl.com
Thu Dec 20 09:20:37 UTC 2001
Have a look at the BSP stack. That's where RTEMS stack can from in the first place.
Good luck.
wkr,
Gerke
*********** REPLY SEPARATOR  ***********
On 20/12/01 at 10:01 Kapil Arora wrote:
>Hi,
>We are trying to segregate the TCP/IP stack from RTEMS
>source to port it to other real-time operating system. Now,
>the issue is that RTEMS's TCP/IP stack seems to be tightly
>coupled with the RTEMS kernel code and using it's functions
>directly which are not mapping to the kernel of the target
>OS. Can anyone help with some documentation available for
>this type of development.
>Thanks in advance,
>Kapil.
