rtems toolset installation on redhat linux7.2
Fri Dec 28 14:30:48 UTC 2001
If you are on Redhat Linux, then I highly recommend
just using the binary RPMs that are distributed with
the RTEMS releases.
Also as a general FYI, the binutils and gdb RPMs provided
with the snapshots work with 4.5.x as well.  It is the
gcc/newlib RPMs that are tightly coupled since the
.h files have to be in agreement between newlib and RTEMS.
The bit script is all but deprecated.  The problem you
are having below appears to be because the binutils were
not in your path when you got to the build of gcc.
--joel
wq wq wrote:
> hello all:
>   I have a simple problem but difficute for me !help
> me please!thanks very much!
>   The follow is the details :
>   I have read the instructions "Getting Started with
> RTEMS for C/C++ Users "
> (donloaded from "http://www.oarcorp.com/rtems/
> releases/4.5.0/rtemsdoc-4.5.0/share/
> rtemsdoc/html/started/index.html")
> and i have follow the instructions getting the
> binutils, gcc and gdb tgz files
> (download from ftp://ftp.oarcorp.com/pub/rtems/
> releases/4.5.0/c_tools/source/) .
> then extract and patch toolset "source file"(not
> install tools from  RPM) ...
> I use "./bit i386-coff " to install.
> |||user.cfg file set:
> INSTALL_POINT=/usr/local/rtems
> BINUTILS=binutils-2.9.5.0.24
> GCC=gcc-2.95.2
> BUILD_OTHER_LANGUAGES=no
> NEWLIB=newlib-1.8.2
> GDB=gdb-4.18
> BUILD_DOCS=yes
> RTEMS=4.5.0
> ENABLE_RTEMS_POSIX=yes
> .....others are all setted by =yes
> |||my pc set:intel 1.5Gmhz cpu,256 ram,40g
> harddisk,3c905 netcard. os is redhat linux 7.2 ver.
> |||bit.log file :
> makeinfo (GNU texinfo) 4.0b
> Copyright (C) 2001 Free Software Foundation, Inc.
> There is NO warranty.  You may redistribute this
> software
> under the terms of the GNU General Public License.
> For more information about these matters, see the
> files named COPYING.
> Building a cross GNU C/C++ toolset with the following
> configuration:
>     BINUTILS      -->  binutils-2.9.5.0.24
>     GCC           -->  gcc-2.95.2
>     NEWLIB        -->  newlib-1.8.2
>     TARGET        -->  i386-rtemscoff
>     INSTALL POINT -->  /usr/local/rtems
>     BUILD DOCS    -->  yes
> Making directory for install point (/usr/local/rtems)
> Compilation of binutils will occur in
> build-i386-coff-tools.
> BIT: Running in /home/tools/build-i386-coff-tools:
> + ../binutils-2.9.5.0.24/configure
> --target=i386-rtemscoff --verbose
> --prefix=/usr/local/rtems
> Configuring for a i686-pc-linux-gnu host.
> Created "Makefile" in
> Configuring intl...
> creating cache ../config.cache
> checking for a BSD compatible install...
> /usr/bin/install -c
> checking how to run the C preprocessor... gcc -E
> + ../gcc-2.95.2/configure --target=i386-rtemscoff
> --with-gnu-as --with-gnu-ld --with-newlib --verbose
> --enable-languages=c,c++ --prefix=/usr/local/rtems
> Configuring libiberty...
> checking host system type... i686-pc-linux-gnu
> checking build system type... i686-pc-linux-gnu
> checking for ar... ar
> do \
>   echo ${name}; \
>   /home/tools/build-i386-coff-tools/gcc/xgcc
> -B/home/tools/build-i386-coff-tools/gcc/
> -B/usr/local/rtems/i386-rtemscoff/bin/
> -I/usr/local/rtems/i386-rtemscoff/include -O2
> -I../../gcc-2.95.2/gcc/../newlib/libc/sys/rtems/include
> -DCROSS_COMPILE -DIN_GCC     -O2 -g -I./include   -g1
> -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc
> -I. -I../../gcc-2.95.2/gcc
> -I../../gcc-2.95.2/gcc/config
> -I../../gcc-2.95.2/gcc/../include -c -DL${name} \
>        ../../gcc-2.95.2/gcc/libgcc2.c -o ${name}.o; \
>   if [ $? -eq 0 ] ; then true; else exit 1; fi; \
>   i386-rtemscoff-ar rc tmplibgcc2.a ${name}.o; \
>   rm -f ${name}.o; \
> done
> _muldi3
> /usr/local/rtems/i386-rtemscoff/bin/as: unrecognized
> option `-Qy'
> gmake[1]: *** [libgcc2.a] Error 1
> gmake[1]: Leaving directory
> `/home/tools/build-i386-coff-tools/gcc'
> gmake: *** [all-gcc] Error 2
> ERROR: **** FAILED **** base build (step 1)
> Started:   Wed Dec 26 11:02:51 HKT 2001
> Finished:  Wed Dec 26 11:08:47 HKT 2001
> Directory size information:
> 30500   build-i386-coff-tools
> 18240   /usr/local/rtems
> The src and build-i386-coff-tools subdirectory have
> NOT been removed.
> Any thoughts or comments would be appreciated!!!
> _________________________________________________________
> Do You Yahoo!? µÇ¼Ãâ·ÑÑÅ»¢µçÓÊ! http://mail.yahoo.com.cn
> <font color=#6666FF>ÎÞÁÄ£¿ÓôÃÆ£¿¸ßÐË£¿Ã»ÀíÓÉ£¿¶¼À´ÁÄÌì°É£¡</font>¡ª¡ª
> ÑÅ»¢È«ÐÂÁÄÌìÊÒ! http://cn.chat.yahoo.com/c/roomlist.html
