network boot
    Chris Johns
    cjohns at cybertec.com.au
    Wed Dec 19 11:03:53 UTC 2001
Davide Del Vento wrote:
> I reply so later because I had problem with my DHCP server.
> My network administrator now gets it work, but there is still a problem: he
> says that I need to tell RTEMS the DHCP server IP-number, but rom-o-matic
> don't ask me for!
Do should not need to.
> When I try to boot with a generated boot image on floppy,
> rtems search for the DHCP server, but it doesn't find and print only dots.
> What's about this?
Is the DHCP server you are to use on the same subnet as the RTEMS
machine ?
 Chris Johns, cjohns at cybertec.com.au
