Soft Float for PC386
angelo
angelo at hunterlink.net.au
Thu Feb 1 23:28:50 UTC 2001
It appears that there may be two different bugs rearing themselves in the same test.
I built and ran the following program on both the 386DX and the Pentium machine
using the
pc386 soft float build
cout <<"test for standard float"<<endl;
float f;
cout <<"float has been declared. Now try some maths"<<endl;
f = 1.11111111 * 1.11111111;
cout <<"float Value :"<<f<<endl;
f = 0;
cout <<"test for double"<<endl;
double d = 1.11111111 * 1.11111111;
cout <<"double Value :"<<d<<endl;
I get two different reactions from each machine. The Pentium displays a rounding
error
from the double. This, I suspect is because the double may really only be a float,
I'm not
sure.
The 386DX displays the exception after executing the line
i.e. we see "float has been declared. Now try some maths" on the console.
After doing some research and testing on this computer, I have discovered it has the
POPAD
fault, which is described as follows:
POPA/POPAD bug
The bug is present in all 386DX chips and in early revisions of 386SX family
models.
If the POPAD instruction is followed by instruction using 32-bit indexed
addressing mode, EAX register content is not properly restored by POPA/POPAD
instruction. The bug is very deterministic, so it can be used to differentiate
between Intel/AMD 386 and other similar processors.
see the URL below.
http://www.grafi.ii.pw.edu.pl/gbm/x86/3486bugs.html
Are there any flags we can place in the build to correct these errors, if indeed
this is
the error?
angelo wrote:
> Successfully built and ran by modifying the following in pc386.cfg
> ifeq ($(RTEMS_CPU_MODEL),)
> RTEMS_CPU_MODEL=i386_nofp
> CPU_CFLAGS =-msoft-float
> endif
> I am not sure whether I should add the -mno-fp-ret-in-387 to the CPU_CFLAGS, I
> have tried both with the same result.
> The target now runs in the PC, however, when I attempt to run the paranoia.exe
> ,I get the following error message
> *** PARANOIA TEST***
> Exception 7 caught at PC 10743 by thread 13428265
> processor execution context at time of the fault was
> EAX = 0 EBX = 134300 ECX = 0 EDX = 0
> ESI = 13414 EDI = 12D878 EBP = 1342A8 ESP = 134268
> Error code pushed by processor itself (if not 0) = 0
> **************** FAULTY THREAD WILL NOW BE DELETED ********************
> I then did a PC 586 build (even with an unmodified pc386.cfg) and tried to run
> paranoia on a Pentium 100 and got this huge message about 4 errors being found.
> These tests have been done with snapshots rtems-ss-20010109 and
> rtems-ss-20010126. Has anyone else tested paranoia.exe on a PC lately and found
> the same problem?
> Joel Sherrill wrote:
> > angelo wrote:
> > > I have successfully run RTEMS apps on a Pentium using the pc386 build,
> > > however, when I attempt to run the apps (including the hello world ) on a
> > > 386 with no co-processor, The console just display an infinite Exception
> > > which I cannot read.
> > Hmmm.. I would be surprised if the lack of an FPU is causing this. But
> > stranger things have happened over the years. What RTEMS version are
> > you trying? It might also be worth it to put a "while 1" loop in the
> > exception handler temporarily so the message won't disappear.
> > > I suspect that it may be that soft float is required,
> > > but I am not sure. Is there a way of ensuring that I am not trying to use
> > > the co-processor and am in fact using the soft floating point libraries.
> > The answer is simple and not so simple at the same time. The standard
> > gcc sources do not have soft-float support turned on for the i386 targets.
> > The RTEMS gcc patches and RPMs post 4.5.0 do include support for this.
> > If you look at the ts_386ex target in recent snapshots, its CPU_CFLAGS
> > should be the basis for adding a new pc386 variant (like pc[56]86 and
> > pck6). Right now all pc386 variants assume an FPU.
> > > Angelo Fraietta
> > > PO Box 859
> > > Hamilton NSW 2303
> > > Home Page
> > > http://users.hunterlink.net.au/~maaaf/
> > > There are those who seek knowledge for the sake of knowledge - that is
> > > CURIOSITY
> > > There are those who seek knowledge to be known by others - that is VANITY
> > > There are those who seek knowledge in order to serve - that is LOVE
> > > Bernard of Clairvaux (1090 - 1153)
> > Joel Sherrill, Ph.D. Director of Research & Development
> > joel at OARcorp.com On-Line Applications Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
