FTPD crashes in rtems-ss-20010126 with passive mode off
OUTWATER ~ KEITH J /5G3110 vac4050 at cae597.rsc.raytheon.com
Mon Feb 5 14:17:42 UTC 2001
> That's a known (and already fixed) problem. The patch is available from me by
> request.
Thanks for the info.  I guess I wasn't paying close enough attention to the
list.
If it's fixed subsequent snapshots, I'll just use the current snapshot.
Keith Outwater
Principal Engineer
Raytheon Missile Systems
Tucson, AZ
(520) 794-2518
> Sergei.
> OUTWATER ~ KEITH J /5G3110 <vac4050 at cae597.rsc.raytheon.com> writes:
> > greetings all -
> >   I found that when using rtems-ss-20010126, ftpd crashes when I do an 'ls'
> > with passive mode on.
> >   With passive mode off, things are fine.
> >   I'm using a stock Redhat 7.0 system on x86.  I also applied the ftpd
patches
> > that appeared recently on the list.
> >   Keith
> > Keith Outwater Principal Engineer Raytheon Missile Systems Tucson, AZ
> > (520) 794-2518 vac4050 at cae597.rsc.raytheon.com
