FTPD crashes in rtems-ss-20010126 with passive mode off
Sergei Organov osv at javad.ru
Mon Feb 5 15:23:54 UTC 2001
OUTWATER ~ KEITH J /5G3110 <vac4050 at cae597.rsc.raytheon.com> writes:
> > That's a known (and already fixed) problem. The patch is available from me by
> > request.
> Thanks for the info.  I guess I wasn't paying close enough attention to the
> list.
No, I just didn't send latest patch to any of RTEMS mailing lists because I
wanted first to simplify FTPD to use latest 'libio' features, and the patch
that I've sent was indeed a little bit broken. I believe next snapshot won't
have these FTPD problems.
> If it's fixed subsequent snapshots, I'll just use the current snapshot.
> Keith Outwater
> Principal Engineer
> Raytheon Missile Systems
> Tucson, AZ
> (520) 794-2518
> > Sergei.
> > > greetings all -
> > >   I found that when using rtems-ss-20010126, ftpd crashes when I do an 'ls'
> > > with passive mode on.
> > >   With passive mode off, things are fine.
> > >   I'm using a stock Redhat 7.0 system on x86.  I also applied the ftpd
> patches
> > > that appeared recently on the list.
> > >   Keith
> > > Keith Outwater Principal Engineer Raytheon Missile Systems Tucson, AZ
> > > (520) 794-2518 vac4050 at cae597.rsc.raytheon.com
