Soft Float for PC386
angelo angelo at hunterlink.net.au
Tue Feb 6 00:45:35 UTC 2001
Has anybody successfully ran paranoia on a PC386, not just the pc386 build, but on
an actual 386 PC?
angelo wrote:
> Successfully built and ran by modifying the following in pc386.cfg
> ifeq ($(RTEMS_CPU_MODEL),)
> RTEMS_CPU_MODEL=i386_nofp
> CPU_CFLAGS =-msoft-float
> endif
> I am not sure whether I should add the -mno-fp-ret-in-387 to the CPU_CFLAGS, I
> have tried both with the same result.
> The target now runs in the PC, however, when I attempt to run the paranoia.exe
> ,I get the following error message
> *** PARANOIA TEST***
> Exception 7 caught at PC 10743 by thread 13428265
> processor execution context at time of the fault was
> EAX = 0     EBX = 134300    ECX = 0    EDX = 0
> ESI = 13414    EDI = 12D878    EBP = 1342A8    ESP = 134268
> Error code pushed by processor itself (if not 0) = 0
> ****************   FAULTY THREAD WILL NOW BE DELETED ********************
> I then did a PC 586 build (even with an unmodified pc386.cfg) and tried to run
> paranoia on a Pentium 100 and got this huge message about 4 errors being found.
> These tests have been done with snapshots rtems-ss-20010109 and
> rtems-ss-20010126.  Has anyone else tested paranoia.exe on a PC lately and found
> the same problem?
> Joel Sherrill wrote:
> > angelo wrote:
> > > I have successfully run  RTEMS apps on a Pentium using the pc386 build,
> > > however, when I attempt to run the apps (including the hello world ) on a
> > > 386 with no co-processor, The console just display an infinite Exception
> > > which I cannot read.
> > Hmmm.. I would be surprised if the lack of an FPU is causing this.  But
> > stranger things have happened over the years.  What RTEMS version are
> > you trying?  It might also be worth it to put a "while 1" loop in the
> > exception handler temporarily so the message won't disappear.
> > > I suspect that it may be that soft float is required,
> > > but I am not sure.  Is there a way of ensuring that I am not trying to use
> > > the co-processor and am in fact using the soft floating point libraries.
> > The answer is simple and not so simple at the same time.  The standard
> > gcc sources do not have soft-float support turned on for the i386 targets.
> > The RTEMS gcc patches and RPMs post 4.5.0 do include support for this.
> > If you look at the ts_386ex target in recent snapshots, its CPU_CFLAGS
> > should be the basis for adding a new pc386 variant (like pc[56]86 and
> > pck6).  Right now all pc386 variants assume an FPU.
> > > Angelo Fraietta
> > > PO Box 859
> > > Hamilton NSW 2303
> > > Home Page
> > > http://users.hunterlink.net.au/~maaaf/
> > > There are those who seek knowledge for the sake of knowledge - that is
> > > CURIOSITY
> > > There are those who seek knowledge to be known by others - that is VANITY
> > > There are those who seek knowledge in order to serve - that is LOVE
> > >     Bernard of Clairvaux (1090 - 1153)
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
