Rebuilding RTEMS
Angelo Fraietta angelo at hunterlink.net.au
Mon Feb 12 02:45:01 UTC 2001
When trying to rebuild RTEMS on Red Hat 6.2, I often get the following
error:
gmake[5]: Entering directory
`/opt/rtems/tools/build-i386-rtems/i386-rtems/c/pc3
86/tests/samples/hello'
i386-rtems-gcc --pipe -B../../../../../pc386/lib/ -specs bsp_specs
-qrtems -g -W
all -ansi -fasm   -msoft-float         -L ../../../../../pc386/lib
-O4  -Wl,-T
text,0x00100000 -o o-optimize/hello.obj o-optimize/init.o
../../../../../pc3
86/lib/no-dpmem.rel ../../../../../pc386/lib/no-event.rel
ib/no-msg.rel ../../../../../pc386/lib/no-mp.rel
../../../../../pc386/lib/no-par
t.rel ../../../../../pc386/lib/no-signal.rel
../../../../../pc386/lib/no-timer.r
el ../../../../../pc386/lib/no-rtmon.rel
/opt/rtems/i386-rtems/bin/ld: cannot open linker script file linkcmds:
No such f
ile or directory
collect2: ld returned 1 exit status
I cannot then get RTEMS to build
I was having trouble like this earlier in the year, and I often had to
physically remove the build-rtems directory or re-install the RPMs.  I
tried this morning a a completely different computer.  I was able to
build RTEMS pc386 the first time, but the second time it failed.
I have been using the build scripts from the beta3a. Are they still the
preferred ones to use?  Any suggestions would be appreciated.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://users.hunterlink.net.au/~maaaf/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is
VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
