Cygwin / Rtems powerpc cross development....
Kirk Bateman
kirk.bateman at esgem.com
Wed Feb 14 15:04:10 UTC 2001
I'm having trouble getting cross development for powerpc to work properly...
On a win98 machine.
I have a cygwin installation which is working fine, building executables for dos system.
cygcheck results are attached incase useful.
Where are the following rpm's supposed to be extracted to ....
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
rtems-base-gdb-4.18-4.i386.rpm
powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm -> tried \cygwin\usr\lib and \cygwin\lib\gcc-lib\ and \ (ie. \opt\rtems.......)
powerpc-rtems-binutils-2.9.5.0.24-1.i386.rpm
After partially putting some files onto the system, trying to compile I get a message saying the linker isn't being used (fine) and also:
"gcc: installation problem, cannot exec'cc1': No such file or directory"
The gcc -print-search-dirs seems to have the correct directory for the files... cc1.exe included
Hopefully someone can be of assistance here... It was soo much easier getting the prc-tools distributions to work with cygwin-b20-full.exe
The latest cygwin configurations are terrible.... and the documentation for rtems relating to cygwin is probably around 5 years out of date ??
If this is resolved, I will update the documentation as to where to install files to get them to work and what paths are required on a win98 host.
Cheers
Kirk Bateman
I don't suffer from insanity, I enjoy every minute of it.
Kirk Bateman
Software Engineer - Esgem Limited
www.esgem.com
Head Office: 30 Long Street, Wotton-under-Edge, Glos GL12 7BT
Registered in England at 4, Bramley Close, Kingswood,
Wotton-under-Edge, Glos GL12 8SF. Reg No. 3372135
URL: <http://lists.rtems.org/pipermail/users/attachments/20010214/1e1b7f5a/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20010214/1e1b7f5a/attachment.txt>
