rtems cygwin cross compiler setup problems (FIXED)
Kirk Bateman
kirk.bateman at esgem.com
Thu Feb 15 15:58:23 UTC 2001
Ok folks,
Thanks for your helpful (and some funny :-) information for trying to resolve my problems....
Eventually I have it working,
Hopefully this information will be useful to someone ?? :-)
Required files:
from cygnus solutions:
cygwin-b20_1-full.exe (if you can't find it ask a gcc palm pilot developer they probably have it)
latest cygwin dll update (you only need the cygwin1.dll but its in the .tgz file)
from oarcorp:
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
powerpc-rtems-binutils-2.9.5.0.24-1.i386.rpm
rtems-base-gcc-gcc2.95.2newlib1.8.2-4.i386.rpm
powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-4.i386.rpm
rtems-base-gdb-4.18-2.i386.rpm
powerpc-rtems-gdb-4.18-2.i386.rpm
also required: rpm extractor for windows (rpm extractor ver 0.99 beta release 5)
Instructions:
Install cygwin-b20_1-full.exe (much nicer install than the new online setup.exe)
Modify path in autoexec.bat to include: c:\CYGNUS\CYGWIN~1\H-I586~1\BIN
Reboot to activate new path
Using rpm extractor for windows extract the files from oarcorp (IN THE ORDER THEY ARE LISTED ABOVE !!!!!)
note that you must exit rpm extractor between each file otherwise it will extract them under each other (very messy) or you
should be able to extract to the root directory
Modify path again: add this before the previous cygnus addition... C:\opt\rtems\powerpc-rtems\bin
Path should now be similar to:
set path=C:\utils;C:\opt\rtems\powerpc-rtems\bin;c:\CYGNUS\CYGWIN~1\H-I586~1\BIN
from the latest cygwin dll update extract the cygwin1.dll and replace the old one.
Reboot machine again to take account of new path....
Hey Presto, the gcc rtems powerpc cross compiler should now work properly.....
Kirk Bateman
I don't suffer from insanity, I enjoy every minute of it.
Kirk Bateman
Software Engineer - Esgem Limited
www.esgem.com
Head Office: 30 Long Street, Wotton-under-Edge, Glos GL12 7BT
Registered in England at 4, Bramley Close, Kingswood,
Wotton-under-Edge, Glos GL12 8SF. Reg No. 3372135
URL: <http://lists.rtems.org/pipermail/users/attachments/20010215/70596015/attachment.html>
