problem of netdemo 4.5.0 example
김안모 kanmo at cisl.snu.ac.kr
Tue Feb 20 12:38:08 UTC 2001
In my example.. there's no CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS definition in init.c of netdemo example.
and. i could just find it in http example.
but. i know that http example and netdemo example are independent.
plz, check it once more.
-----Original Message-----
From: Nick.SIMON at syntegra.bt.co.uk [mailto:Nick.SIMON at syntegra.bt.co.uk]
Sent: Tuesday, February 20, 2001 8:31 PM
To: kanmo at cisl.snu.ac.kr; rtems-users at oarcorp.com
Subject: RE: Error on netdemo 4.5.0 example
It could be you haven't got enough file handles.  Look in init.c for
definition of CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS.
-- Nick Simon
> From: kanmo at cisl.snu.ac.kr [mailto:kanmo at cisl.snu.ac.kr]
> Sent: 20 February 2001 10:58
> To: rtems-users
> Subject: Error on netdemo 4.5.0 example
> we build rtems system on the system of i386 processor and pc386 bsp.
> And we use ISA 3c509 network card.
> However, we met a problem on the execution of netdemo program.
> we think that the configuration is right.
> the execution screen is as follows. it shows error message.
> 3C509: attach() called
> 3C509: isa_probe() looking for a card
> 1 3C5x9 board(s) on ISA found at 0x300
> 3C509: I/O=0x300, IRQ=10, CONNECTOR=UTP, ADDRESS=0xa0 2407 1015
> 3c509: attach() is complete
> Can't create initial socket: Too many open files in system
> No routes!
> Create Socket
> RTEMS: Can't create socket: Too many open files in system
> RTEMS: fatal error, exiting
> EXECUTIVE SHUTDOWN! Any key to reboot...
> plx, help~~
> good luck for all of you.
Check us out at http://www.syntegra.com
