RTEMS
Mon Feb 26 19:31:00 UTC 2001
Jiri Gaisler wrote:
> azzedine abdenoure wrote:
> > Hello,
> > I come from begin the programming with RTEMS, for the processor
> > LEON(compatible SPARC), for compilation I use the tools leonccs-2.0.7  my
> > objective is to learn the programming one uses the primitives of RTEMS,
> > therefore if it possible of my is sent programs (examples) explain  differ
> > them possibility of programming.
> I would recommend that you switch to the LECCS compiler system
> (see www.gaisler.com), which is based on rtems-4.5.0, rather than
> rtems-4.0.0 in leonccs. For example programs, download the rtems
> sources from www.rtems.com and look at the rtems validation test,
> they show how most of the real-time primitives are used.
If you are looking at coding classic textbook problems in RTEMS
(producer/consumer, message server, etc), it would be nice to
package them and including them as examples.
Be warned the RTEMS tests are usually API tests and not necessarily
the "normal" way to write tasking code. :)
> Jiri.
> Gaisler Research, Plantageg. 5, 41305 Goteborg, Sweden, +46-73-9927100
> email: jiri at gaisler.com, home page: http://www.gaisler.com
