Anyone using Redhat 7.0 xinet/tftpd with RTEMS?
OUTWATER ~ KEITH J /5G3110
vac4050 at cae597.rsc.raytheon.com
Thu Feb 1 23:36:20 UTC 2001
> OUTWATER ~ KEITH J /5G3110 wrote:
> > Greetings all -
> > I've just started using Redhat 7.0 x86 and I think I have xinet and tftpd
set up
> > right (on the host I can tftp to itself and get files).
> > When I try to tftp from RTEMS, the file open fails with "not owner".
> > I've messed around with permoissions and ownership on the host, but no luck.
> > Has anyone gotten RTEMS tftp to work with a redhat 7.0 host?
> Works for me....with 20010109 snapshot.
> The salient portion of my /etc/hosts.allow file has -- norumx1 and
> norumx2 are my RTEMS TFTP clients -- pretty imaginative names, right?
> in.tftpd:norum1.usask.ca \
> norumx1 norumx1.usask.ca \
> norumx2 norumx2.usask.ca
> My /etc/xinetd.d/tftp contains
> service tftp
> socket_type = dgram
> wait = yes
> user = nobody
> log_on_success += USERID
> log_on_failure += USERID
> server = /usr/sbin/in.tftpd
> server_args = -s /tftpboot
> disable = no
Are you using bootpd? If so, what are you using for :hd and :bf params?
Do you put you boot files in /tftpboot/<file to boot> ?
Keith
> Eric Norum eric.norum at usask.ca
> Department of Electrical Engineering Phone: (306) 966-5394
> University of Saskatchewan FAX: (306) 966-5407
> Saskatoon, Canada.
