ERC32 BSP : Real Time Clock Problem
Thu Feb 8 13:22:54 UTC 2001
Antonio da Silva Fariña wrote:
> Hi,
> I have problems with applications which define
> CONFIGURE_APPLICATION_NEEDS_CLOOK_DRIVER
> These applications crash into Install_clock function during the
> rtems_io_initialize phase.
I suspect that there is some conflict over whether your
trap table is in ROM/RAM.  The sparc port can put the
trap table in either place.
> If CONFIGURE_APPLICATION_NEEDS_CLOOK_DRIVER is
> not define application starts, tasks are created but calls like
> rtems_task_wake_after does not work, of course.
That's the obvious side-effect.  Other less obvious things
won't work either. :)
> Now I'm using the new LECCS compiler system, but the
> problem must be in board.
Probably not a compiler issue -- a board memory versus
BSP layout.
> Any idea...
> Thanks
> _______________________________________________________________________
>  DIATEL-UPM                URL:    http://www.diatel.upm.es/~adasilva/
>  EUIT Telecomunicación     mailto: adasilva at diatel.upm.es
>  Ctra. Valencia, Km. 7  Tel: +34 91 3367812   Fax: +34 91 3367817
>  28031 Madrid, SPAIN
> _________________________________________________________________________
