rtems cygwin cross compiler setup problems (FIXED)
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Fri Feb 16 08:05:06 UTC 2001
> -----Mensaje original-----
> De: Correo Fernando-ruiz (E-mail) [mailto:correo at fernando-ruiz.com]
> Enviado el: jueves, 15 de febrero de 2001 23:42
> Para: 'Kirk Bateman'
> CC: Rtems-Users (E-mail)
> Asunto: RE: rtems cygwin cross compiler setup problems (FIXED)
> Congratulations.
> I have only the B19. Now the B20 release of cygwin is not
> availiable from
> cygnus. I can't find it.
> Where is the place to download it?
Find ii!!
http://www.palmos.com/dev/tech/tools/gcc/dist/cygwin-b20.1-full.exe
> Fernando RUIZ CASAS
> home: correo at fernando-ruiz.com
> work: fernando.ruiz at ctv.es
> De: Kirk Bateman [mailto:kirk.bateman at esgem.com]
> Enviado el: jueves, 15 de febrero de 2001 16:58
> Para: rtems-users
> Asunto: rtems cygwin cross compiler setup problems (FIXED)
> Ok folks,
> Thanks for your helpful (and some funny :-) information for trying to
> resolve my problems....
> Eventually I have it working,
> Hopefully this information will be useful to someone ?? :-)
> Required files:
> from cygnus solutions:
> cygwin-b20_1-full.exe (if you can't find
> it ask a gcc
> palm pilot developer they probably have it)
> latest cygwin dll update (you only need the
> cygwin1.dll but
> its in the .tgz file)
> from oarcorp:
> rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> powerpc-rtems-binutils-2.9.5.0.24-1.i386.rpm
> rtems-base-gcc-gcc2.95.2newlib1.8.2-4.i386.rpm
> powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-4.i386.rpm
> rtems-base-gdb-4.18-2.i386.rpm
> powerpc-rtems-gdb-4.18-2.i386.rpm
> also required: rpm extractor for windows (rpm extractor
> ver 0.99 beta
> release 5)
> Instructions:
> Install cygwin-b20_1-full.exe (much nicer
> install than
> the new online setup.exe)
> Modify path in autoexec.bat to include:
> c:\CYGNUS\CYGWIN~1\H-I586~1\BIN
> Reboot to activate new path
> Using rpm extractor for windows extract the files
> from oarcorp
> (IN THE ORDER THEY ARE LISTED ABOVE !!!!!)
> note that you must exit rpm extractor between each file
> otherwise it will extract them under each other (very messy) or you
> should be able to extract to the root directory
> Modify path again: add this before the previous cygnus
> addition... C:\opt\rtems\powerpc-rtems\bin
> Path should now be similar to:
> set
> path=C:\utils;C:\opt\rtems\powerpc-rtems\bin;c:\CYGNUS\CYGWIN~
> 1\H-I586~1\BIN
> from the latest cygwin dll update extract the
> cygwin1.dll and
> replace the old one.
> Reboot machine again to take account of new path....
> Hey Presto, the gcc rtems powerpc cross compiler
> should now work
> properly.....
> Kirk Bateman
> I don't suffer from insanity, I enjoy every minute of it.
> Kirk Bateman
> Software Engineer - Esgem Limited
> www.esgem.com
> Head Office: 30 Long Street, Wotton-under-Edge, Glos GL12 7BT
> Registered in England at 4, Bramley Close, Kingswood,
> Wotton-under-Edge, Glos GL12 8SF. Reg No. 3372135
