driver APIs
Fernando RUIZ CASAS
correo at fernando-ruiz.com
Tue Jan 2 23:51:39 UTC 2001
Here.
My provisional development for a RTEMS BSP.
This is published only to discuss it.
This is property of VILLAVICIOSA TELECOMUNICACIONES (VISATEL)
If anything is good for you enjoy it.
Includes drivers for:
FLASH AMD 29F040
XICOR e2p Serial I2C memory
SCI Hitachi And 16450 UART Termios Terminal drivers. (Console.c) With
interrupts.
Propietary NET Protocol.
Multiple remote shell sessions (including all monitor commands and more)
A little app test.
Thanks at all that make possible this marvel. The RTEMS.
A free OS system with a very good list of discussion.
Thanks specially at Ralf for his port to Hitachi (A big work) and Joel
for his dedication.
All of this can be founded in:
http://development.fernando-ruiz.com
comments: mailto:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: Tom Knox [mailto:tom at wintegrative.com]
> Enviado el: sábado, 30 de diciembre de 2000 1:27
> Para: correo at fernando-ruiz.com
> CC: aaron at frye.com
> Asunto: RE: driver APIs
> I look for drivers for flash, e2prom, 16450 UART, etc also.
> I am using
> 68332. Any help would be good!
> Tom
> > -----Original Message-----
> > From: Fernando RUIZ CASAS [mailto:correo at fernando-ruiz.com]
> > Sent: Friday, December 29, 2000 4:04 PM
> > To: 'Aaron J. Grier'
> > Cc: Rtems-Users (E-mail)
> > Subject: RE: driver APIs
> > > De: Aaron J. Grier [mailto:aaron at frye.com]
> > > Enviado el: viernes, 29 de diciembre de 2000 4:06
> > > Para: Fernando RUIZ CASAS
> > > Asunto: Re: driver APIs
> > > On Thu, Dec 28, 2000 at 10:36:47PM +0100, Fernando RUIZ
> CASAS wrote:
> > > > After several tries I have writed drivers for flash
> memory, e2prom
> > > > (serial like I2C memory), termios 16450 UART and several remote
> > > > consoles, multiuser environment, etc...
> > > > Are you interested? My sources are for you if you are
> interested.
> > > ¡sí, por supuesto! :)
> > > I have i²c EEROM, flash, and a 16550 serial port on my 68331-based
> > > target. if your exact hardware is different than mine,
> it would still
> > > be good to maintain a consistent driver API for things
> like flash and
> > > EEROM.
> > > > RTEMS works very well. I am developping a multicpu
> (serial linked)
> > > > telephonic concentrator (public interphone, normal telephony and
> > > > command telephone) in a prototype. All of drivers works
> correctly.
> > > > I would contribute to RTEMS with the sources but I have
> a problems
> > > > because RTEMS need sources independent of BSP. I need build the
> > > > sources into ../libchip/.. directory and the sources
> > > configurables for
> > > > all BSP. Now my efforts are based in to develope my
> BSP. After the
> > > > generalization of drivers.
> > > Yes. :) I am also at this stage with my drivers.
> > > Aaron J. Grier | Frye Electronics, Tigard, OR |
> > > aaron at frye.com
> > > "Calling anything from the x86 world a 'masterpiece'
> seems, to me,
> > > like putting a gold star on the best-looking
> > > fingerpainting in the
> > > special-needs Kindergarten class." -- Wakko Warner
> > Do you want see my driver sources and to share the background?
> > Perhaps our efforts can be reduced if we share the information to
> > build the
> > same
> > objectif.
> > Don't have a little source code to start in the world of
> drivers is very
> > hard.
> > We can share it.
> > I have a web page to put it.
> > My problem is the english.
> > Can you translate my spanish?
> > Best regards.
> > Fernando RUIZ CASAS
