Events.
Correo Fernando-ruiz (E-mail) correo at fernando-ruiz.com
Wed Jan 10 21:51:27 UTC 2001
Hi Joel and rtems-users.
I have a question about events.
I have implemented an event dispatcher and
I want to known if I am in the right way.
1. Environment.
   Two cpu's need to comunicate and the first send a command towards the
second.
   The second take a while and sends the reply.
   The caller task need to wait the reply until it arrives.
   The reply is catched by another task (dispatcher & supervisor).
2. Event handler.
   Every task can manage a maximum of 32 events. (RTEMS LIMITS)
   The availiable events are known by every task.
   To avoid the duplicates in lieu of a constant event
   the task call to lock for a new free event availiable
   and it is stored in a var.
   A events mask for every task is placed in a handlers table.
   typedef struct {
    rtems_id        id;    /* TASK ID */
    rtems_event_set event;
   } THndEvent;
   static THndEvent tbl_events[MAX_EVENTS];  /* The handlers */
   static THndEvent msk_events[TSK_EVENTS];  /* The task mask */
   static int last_event;                    /* this works like a PID inc
every time */
   static int max_msk_event;
  rtems_status_code lock_event(rtems_event_set * event) {
   rtems_status_code sc;
   rtems_event_set * mask,
                     ignored;
   sc=get_msk_events((rtems_id)0,&mask);
   if (sc!=RTEMS_SUCCESSFUL) return sc;
   *event=RTEMS_EVENT_0;
   while (*event&*mask) {
    *event<<=1;
    if (!*event) return RTEMS_TOO_MANY;
   rtems_event_receive(*event,RTEMS_NO_WAIT,0,&ignored); /* clear it */
   *mask|=*event;
   return RTEMS_SUCCESSFUL;
   With this a new procedure
   rtems_status_code set_event(int *handle,rtems_event_set * event) ;
   gives a handler and the new event locked.
   The first task places this handler in the comand sended towards the
second cpu.
   When the reply arrives the dispatcher task calls to
 void free_event(int handle) {
  if (handle<0) return;
  if (handle>=MAX_EVENTS)  return;
  if (tbl_events[handle].event) {
   sc=rtems_event_send(tbl_events[handle].id,tbl_events[handle].event);
   if (sc!=RTEMS_SUCCESSFUL) rtems_error(sc,"send event to
%08X",tbl_events[handle].id);
   unlock_event(tbl_events[handle].id,tbl_events[handle].event);
   tbl_events[handle].id   =0;
   tbl_events[handle].event=0;
   freeing the handle and sending the event at the first task.
   How the first task waits for this event the process is completed.
   Question:
	Is this way the right way to resolve this kind of problems?
	Where is the place in RTEMS to put the task mask used events?
	With this place I can eliminate this
   rtems_status_code get_msk_events(rtems_id task_id,rtems_event_set **
msk);
  The module includes also:
   void send_event(int handle) ; to wake_up asyncronously.
   void clear_events(rtems_event_set event); unlock the event and
                                             the handler for current task
   rtems_interval msecs2ticks(int msecs) ;
   rtems_status_code wait_event(rtems_event_set ev,rtems_interval msecs);
   With this last procedure I can use it like rtems_monotonic waiting a
   locked event known only by the current task.
/*-  My shell command to spy the module              -*/
#include <shell.h>
int main_events(int argc,char * argv[]) {
 int n,i,num;
 rtems_event_set ev;
 printf("MSK EVTS           1         2         3 \n");
 printf("TASK ID  01234567890123456789012345678901\n");
 printf("-------- --------------------------------\n");
 for (n=0;n<max_msk_event;n++) {
  printf("%08X ",msk_events[n].id);
  ev=RTEMS_EVENT_0;
  for (i=0;i<32;i++) {
   putchar(msk_events[n].event&ev?'X':' ');
   ev<<=1;
  putchar('\n');
 printf("%d tasks\n",max_msk_event);
 printf("TBL EVTS           1         2         3 \n");
 printf("TASK ID  01234567890123456789012345678901 HND\n");
 printf("-------- -------------------------------- ---\n");
 num=0;
 for (n=0;n<MAX_EVENTS;n++) {
  if (tbl_events[n].id) {
   num++;
   printf("%08X ",tbl_events[n].id);
   ev=RTEMS_EVENT_0;
    putchar(tbl_events[n].event&ev?'X':' ');
    ev<<=1;
   printf(" %3d\n",n);
 printf("%d events activated\n",num);
 return 0;
Thanks for your comments.
Fernando RUIZ CASAS
fernando.ruiz at ctv.es
