system halted after loading 'hello.exe'
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 11 13:53:02 UTC 2001
rtems wrote:
> Hi, Joel
> I use rtems4.0.0 and try "hello.exe" on a few computers listed below:
> (I also download the sample "microwindows" for rtems4.5.0 and try it.)
> CPU-----------video card-----loading "hello.exe"-----loading microwindows
> intel 386--------ISA-----------------OK----------------------OK
> AMD K5-100-------PCI---------------failed--------------------OK
> intel PII350-----AGP---------------failed--------------------OK
> intel PIII450----AGP---------------failed--------------------OK
> intel PIII500----AGP---------------failed--------------------OK
> intel PIII600----AGP-----------------OK----------------------OK
Then this is the 4.0 hello and 4.5 microwindows. If so, then
that explains it all. Some initialization problems were fixed
between those two points.
> Another problem:
> I need a patch for microwindows, at
> ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/contrib/microwindows/microwin-0.88pre8-rtems.patch
> I found the size of file "microwin-0.88pre8-rtems.patch" is zero bytes,
> where can I get it?
4.5.0-beta SHOULD no be longer there but is. Try 4.5.0 instead.
ftp://ftp.oarcorp.com/pub/rtems/releases/4.5.0/contrib/microwindows/
> Thank you.
> Rick
> ----- Original Message -----
> From:Joel Sherrill <joel.sherrill at OARcorp.com>
> To:rtems <rtems at sina.com>
> Subject:Re: system halted after loading "hello.exe"
> Date:Wed, 10 Jan 2001 21:51:28 +0800
> >rtems wrote:
> >> Thank you for your help.
> >> Now I can get a bootable disk under your instructions,but i meet another problem. On some kind of computers i can boot rtems and see "hello world" messages, on some kind of compters i can't see these messages, after loading "hello.exe", it appears:
> >> kernel=(fd0)/hello.exe
> >> [NetBSD-a.out, loadaddr=0x100000, text=0x14bd0, C, data=0xd68, bss=0x4c78, entry=0x100000]
> >> then system halted.
> >> Did you meet this problem before?
> >> How to solve it ,please help me.
> >You have to provide more information.
> >+ What version of RTEMS are you using?
> >+ Describe the PCs it does not work on.
> >> regards,
> >> Rick
> >> From:"Robert Daniels" <robertd at vantageinc.com>
> >> To:"'rtems'" <rtems at sina.com>
> >> Subject:RE: how to boot hello.exe from floppy disk?
> >> Date:Tue, 9 Jan 2001 24:18:02 +0800
> >> >I found some instructions on exactly how to do this in the
> >> >c/src/lib/libbsp/i386/pc386/HOWTO file. I was able to get a bootable disk
> >> >to work from these instructions. It involved using two disks to create one
> >> >bootable disk.
> >> >Robert Daniels
> >> > -----Original Message-----
> >> >From: rtems [mailto:rtems at sina.com]
> >> >Sent: Tuesday, January 09, 2001 8:08 AM
> >> >To: rtems-users at oarcorp.com
> >> >Subject: how to boot hello.exe from floppy disk?
> >> >CPU=i386 bsp=pc386
> >> >i have built "hello.exe" and use GRUB to boot it from my hard disk
> >> >successfully, but i can't boot it from one floppy disk.
> >> >i download GRUB-0.5.94 to generate stage1 and stage2, use "dd" copy it to
> >> >one floppy disk, but when i use "root (fd0)", it tell me "unknown file
> >> >system" ,so i can't copy "hello.exe" to this floppy disk, what should i do
> >> >next?
> >> >thank you
> >> >Rick
> >> >______________________________________
> >> >ÐÂÀËÃâ·Ñµç×ÓÓÊÏä http://mail.sina.com.cn
> >> >ÄãÑ¡ÊÖ"úÎÒÂòµ¥£?http://mall.sina.com.cn/yesmobile/)
> >> ÄãÑ¡ÊÖ»úÎÒÂòµ¥£¡(http://mall.sina.com.cn/yesmobile/)
> >Joel Sherrill, Ph.D. Director of Research & Development
> >joel at OARcorp.com On-Line Applications Research
> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
