Changed FTPD.
Sergei Organov
osv at javad.ru
Thu Jan 11 19:05:44 UTC 2001
Hello,
I've finished a bunch of changes to the RTEMS FTP server. If the changes seem
to be promising, I'll be glad to submit them to RTEMS maintainers.
Here is the list of changes:
- use pool of pre-created threads to handle sessions instead of
creating/deleting threads on the fly
- LIST output is now similar to what "/bin/ls -al" would output, thus
FTP clients such Netscape are happy with it.
- LIST NAME now works (both for files and directories)
- added support for NLST, CDUP, and MDTM FTP commands to make more FTP clients
happy
- keep track of CWD for every session separately
- ability to specify root directory name for FTPD in configuration table. FTPD
will then create illusion for FTP clients that this is actually root
directory.
- ignore options sent in commands, thus LIST -al FILE works and doesn't try to
list "-al" directory.
- buffers are allocated on stack instead of heap where possible to eliminate
malloc/free calls (avoid possible heap fragmentation troubles).
- drop using of task notepad to pass parameters - use function arguments
instead
- use snprintf() instead of sprintf() everywhere as the latter is unsafe
- use of PF_INET in socket() instead of AF_INET
Here are ftp clients I've tried new FTPD with
(all of them running on Debian GNU/Linux 2.2):
Lftp 2.1.10
NcFTP 2.4.3
Netscape 4.75
ftp
mc 4.5.49
BR,
Sergei Organov.
