gensh2 questions
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Fri Jan 12 14:53:09 UTC 2001
> -----Mensaje original-----
> De: Radzisław Galler [mailto:rgaller at et.put.poznan.pl]
> Enviado el: viernes, 12 de enero de 2001 11:06
> Para: joel.sherrill at OARcorp.com; John Mills; Ralf Corsepius;
> Asunto: Re: gensh2 questions
> *** HELLO WORLD TEST ***
> Hello World
> Hello Joel
> Hello Ralf
> Hello John
> Hello Fernando
> Baudrate is: 115200 bps
> *** END OF HELLO WORLD TEST ***
> ...and the LED is off :) I also run 'paranoia', 'ticker' etc.
> ('unlimited'
> screwed a bit)
> Now starting to write my application. I want to use console
> with echoing.
> First try failed - I used procedure from libtests/termios -
> no echo while
> typing. Also libtests/termios itself didn't show the typed characters
> immediately - only after next printf with some string ended with '\n'.
> JOEL> If you have spotted something incorrect, please fix it
> in your copy
> JOEL> and send a diff.  I would be happy to see corrections.
> As soon as I find out how to do that I'll send them to you.
> JOEL> Additions are welcomed as well.  I know you have had to
> put together
> JOEL> a procedure to download/debug.  Putting that information in the
> JOEL> readme is valuable.
> JOEL>
> JOEL> It would be most appreciated.  This is how open source
> is supposed
> JOEL> to work. :)
> Looks like a first step to become famous &:^) OK. I'll write
> some readme.
> Regards
> Radek
Radek.
In my bsp MCU424 (http://development.fernando-ruiz.com) you
have the sources from 'console.c' & 'sci.c' to implement termios (echoing,
tcsetattr, etc...)
to implement an termios console with interrupts.
They work fine.
Very easy to adapt to SH2 (the same philosophy).
Regards.
