Memory leak when using GoAhead webserver.
Jake Janovetz janovetz at uiuc.edu
Thu Jan 18 14:25:07 UTC 2001
Note, RTEMS has a new socket access layer for the new GoAhead
webserver, so this is probably the first place to look.  This
new socket stuff also is _extremely_ slow, so it should be replaced
anyhow.  I haven't (and don't) have the time to look into the
changes in GoAhead since the last version, so I don't know why
the new socket stuff was needed.
    Jake
On Thu, Jan 18, 2001 at 01:37:04PM -0000, Nick.SIMON at syntegra.bt.co.uk wrote:
> Hi,
> I'm experiencing loss of heap when retrieving pages from webserver, about
> 500 bytes a time.  As the NT test version also has goahead, and doesn't lose
> heap, I suspect IMFS (where html files are kept) or possibly sockets.  I'll
> do some tests to isolate this when I can get to a target but, in the
> meantime, has anyone any knowledge of this?
> I'm using 4.5.0 beta3a with both standard and snapshot 20001219 versions of
> GoAhead.
> Regards,
> -- Nick Simon
> Check us out at http://www.syntegra.com
