RTEMS monitor question
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Tue Jan 30 09:00:49 UTC 2001
> -----Mensaje original-----
> De: cjohns at kiwi.objectivedesign.com.au
> [mailto:cjohns at kiwi.objectivedesign.com.au]En nombre de Chris Johns
> Enviado el: lunes, 29 de enero de 2001 23:00
> Para: rtems-users at oarcorp.com
> Asunto: Re: RTEMS monitor question
> OUTWATER ~ KEITH J /5G3110 wrote:
> > Greetings all -
> > I'm using the RTEMS monitor in the latest snapshot.
> > The README mentions that the user "Can abbreviate commands
> to uniquity" but
> > this does not seem to be implemented.
> > Is anyone currently working on this?
> I may have broken this when I changed the monitor to allow commands to
> be added at runtime.
>  Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
Yes, sir.
And repeat last command is very awfull.
After add a flash erase command all times that I press enter a new flash
erase is called.
I propose add a little 'r' (repeat) command... Two keys for the same
propose.
Regards.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
