Changed FTPD.
Jake Janovetz
janovetz at uiuc.edu
Thu Jan 11 20:53:51 UTC 2001
I'd like that, but (to my knowledge) FTP doesn't supply the size of
a file before it transmits it. It could be realloc'ed, but that
gets expensive. Any better ideas?
Jake
On Thu, Jan 11, 2001 at 12:55:57PM -0700, OUTWATER ~ KEITH J /5G3110 wrote:
> Ditto. They're real handy.
> BTW Jake, is there any pratical way to eliminate the requirement to specify the
> buffer size for the hooks? Could it be dynamically allocated and be allowed to
> grow to the system memory limits?
> Keith
> > This all sounds very good to me! (as long as you keep the FTP
> > hooks in there, I'm happy -- I don't know about others, but I
> > do use them)
> > Jake
> > On Thu, Jan 11, 2001 at 10:05:44PM +0300, Sergei Organov wrote:
> > > Hello,
> > > I've finished a bunch of changes to the RTEMS FTP server. If the changes
> seem
> > > to be promising, I'll be glad to submit them to RTEMS maintainers.
> > > Here is the list of changes:
> > > - use pool of pre-created threads to handle sessions instead of
> > > creating/deleting threads on the fly
> > > - LIST output is now similar to what "/bin/ls -al" would output, thus
> > > FTP clients such Netscape are happy with it.
> > > - LIST NAME now works (both for files and directories)
> > > - added support for NLST, CDUP, and MDTM FTP commands to make more FTP
> clients
> > > happy
> > > - keep track of CWD for every session separately
> > > - ability to specify root directory name for FTPD in configuration table.
> FTPD
> > > will then create illusion for FTP clients that this is actually root
> > > directory.
> > > - ignore options sent in commands, thus LIST -al FILE works and doesn't try
> to
> > > list "-al" directory.
> > > - buffers are allocated on stack instead of heap where possible to eliminate
> > > malloc/free calls (avoid possible heap fragmentation troubles).
> > > - drop using of task notepad to pass parameters - use function arguments
> > > instead
> > > - use snprintf() instead of sprintf() everywhere as the latter is unsafe
> > > - use of PF_INET in socket() instead of AF_INET
> > > Here are ftp clients I've tried new FTPD with
> > > (all of them running on Debian GNU/Linux 2.2):
> > > Lftp 2.1.10
> > > NcFTP 2.4.3
> > > Netscape 4.75
> > > ftp
> > > mc 4.5.49
> > > BR,
> > > Sergei Organov.
