ts_386 build
Tue Jan 23 13:02:01 UTC 2001
This indicates that the toolset you are using is not
the right set of versions/patchesconfiguration for the
beta version.
The RPMs included with the releases/snapshots are
in sync.
Also you might waht to consider using the final release.
angelo wrote:
> I am unable to build the ts_386 target
> I am assuming that this is soft floating point bsp
> I did the following
> 4.5.0-beta3a/configure --target=i386-rtems --prefix=/opt/rt
> ems --disable-hwapi --disable-multiprocessing --enable-cxx --enable-rdbg
> --disab
> le-tests --enable-networking --enable-posix --enable-itron
> and then I then do
> make RTEMS_BSP="ts_386ex"
> and get the following error after a while
> s.h:198: warning: `_CLOCKID_T_' redefined
> ../../../../../../../ts_386ex/lib/include/machine/types.h:29: warning:
> this is t
> he location of the previous definition
> /opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/include/sys/type
> s.h:199: warning: `_TIMER_T_' redefined
> ../../../../../../../ts_386ex/lib/include/machine/types.h:30: warning:
> this is t
> ../../../../../../../../4.5.0-beta3a/c/src/lib/libbsp/i386/ts_386ex/startup/../.
> ./../shared/sbrk.c:27: conflicting types for `sbrk'
> /opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/include/sys/unis
> td.h:57: previous declaration of `sbrk'
> gmake[6]: *** [o-optimize/sbrk.o] Error 1
> gmake[6]: Leaving directory
> `/opt/rtems/tools/i386-rtems/c/ts_386ex/lib/libbsp/i
> 386/ts_386ex/startup'
> gmake[5]: *** [all-recursive] Error 1
> gmake[5]: Leaving directory
> 386/ts_386ex'
> gmake[4]: *** [all-recursive] Error 1
> gmake[4]: Leaving directory
> 386'
> gmake[3]: *** [all-recursive] Error 1
> gmake[3]: Leaving directory
> `/opt/rtems/tools/i386-rtems/c/ts_386ex/lib/libbsp'
> gmake[2]: *** [all-recursive] Error 1
> gmake[2]: Leaving directory `/opt/rtems/tools/i386-rtems/c/ts_386ex'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/opt/rtems/tools/i386-rtems/c'
> make: *** [all-recursive] Error 1
> [root at server tools]#
> doing
>     make RTEMS_BSP="pc386"
> works fine
> What have I done wrong
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://users.hunterlink.net.au/~maaaf/
> There are those who seek knowledge for the sake of knowledge - that is
> CURIOSITY
> There are those who seek knowledge to be known by others - that is
> VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
