ts_386 build
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Jan 23 20:11:39 UTC 2001
Gerke Kok wrote:
> Where do we get the final releases?
Hmmm .. take a guess. :)
ftp://ftp.oarcorp.com:/pub/rtems/releases/4.5.0
> -----Oorspronkelijk bericht-----
> Van: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Verzonden: Tuesday, January 23, 2001 14:02
> Aan: angelo
> CC: rtems-users
> Onderwerp: Re: ts_386 build
> This indicates that the toolset you are using is not
> the right set of versions/patchesconfiguration for the
> beta version.
> The RPMs included with the releases/snapshots are
> in sync.
> Also you might waht to consider using the final release.
> angelo wrote:
> > I am unable to build the ts_386 target
> > I am assuming that this is soft floating point bsp
> > I did the following
> > 4.5.0-beta3a/configure --target=i386-rtems --prefix=/opt/rt
> > ems --disable-hwapi --disable-multiprocessing --enable-cxx --enable-rdbg
> > --disab
> > le-tests --enable-networking --enable-posix --enable-itron
> > and then I then do
> > make RTEMS_BSP="ts_386ex"
> > and get the following error after a while
> > s.h:198: warning: `_CLOCKID_T_' redefined
> > ../../../../../../../ts_386ex/lib/include/machine/types.h:29: warning:
> > this is t
> > he location of the previous definition
> /opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/include/sys/
> type
> > s.h:199: warning: `_TIMER_T_' redefined
> > ../../../../../../../ts_386ex/lib/include/machine/types.h:30: warning:
> > this is t
> ../../../../../../../../4.5.0-beta3a/c/src/lib/libbsp/i386/ts_386ex/startup/
> > ./../shared/sbrk.c:27: conflicting types for `sbrk'
> unis
> > td.h:57: previous declaration of `sbrk'
> > gmake[6]: *** [o-optimize/sbrk.o] Error 1
> > gmake[6]: Leaving directory
> > `/opt/rtems/tools/i386-rtems/c/ts_386ex/lib/libbsp/i
> > 386/ts_386ex/startup'
> > gmake[5]: *** [all-recursive] Error 1
> > gmake[5]: Leaving directory
> > 386/ts_386ex'
> > gmake[4]: *** [all-recursive] Error 1
> > gmake[4]: Leaving directory
> > 386'
> > gmake[3]: *** [all-recursive] Error 1
> > gmake[3]: Leaving directory
> > `/opt/rtems/tools/i386-rtems/c/ts_386ex/lib/libbsp'
> > gmake[2]: *** [all-recursive] Error 1
> > gmake[2]: Leaving directory `/opt/rtems/tools/i386-rtems/c/ts_386ex'
> > gmake[1]: *** [all-recursive] Error 1
> > gmake[1]: Leaving directory `/opt/rtems/tools/i386-rtems/c'
> > make: *** [all-recursive] Error 1
> > [root at server tools]#
> > doing
> > make RTEMS_BSP="pc386"
> > works fine
> > What have I done wrong
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > http://users.hunterlink.net.au/~maaaf/
> > There are those who seek knowledge for the sake of knowledge - that is
> > CURIOSITY
> > There are those who seek knowledge to be known by others - that is
> > VANITY
> > There are those who seek knowledge in order to serve - that is LOVE
> > Bernard of Clairvaux (1090 - 1153)
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
