rtems_libio_set_private_env() and chroot().
Wed Jan 31 16:52:42 UTC 2001
Sergei Organov wrote:
> I've found that for some reason prototype for `rtems_libio_set_private_env()'
> has been put into `libio_.h', not in `libio.h'. Is it a mistake, or I need to
> include file marked "Libio internal information" into my code?
It is s mistake.  It is part of the public interface and should be in libio.h
> Also, prototype for `chroot()' just doesn't seem to exist, but that's a
> `newlib' issue as far as I understand.
I would agree.  The Linux man page and OpenGroup page want it to
be prototyped by including <unistd.h>.  It is prototyped in
newlib's <sys/unistd.h> and is conditional on Cygwin.  It should
also be enabled for __rtems__.
I will fix this so it shows up in the next tool patch and RPMs.
> Sergei.
