Comm ports on Pc386
Angelo Fraietta
angelo at hunterlink.net.au
Mon Jul 2 01:38:13 UTC 2001
I am using the previous snapshot as do not have networking enabled. I am
trying to open the commport and write some chars (for now). If I just try to
open the port without the code you provided, the file does not open. I assume
it is because the port has to be configured with the code you provided.
However, trying to compile this below, I get a heap of parse errors in
ttr_drv.h.
Is this because of the snapshot or am I doing something wrong here?
#include <tty_drv.h>
#include <console.h>
#include <clockdrv.h>
#include <timerdrv.h>
rtems_driver_address_table Device_drivers[] = {
CONSOLE_DRIVER_TABLE_ENTRY,
TTY1_DRIVER_TABLE_ENTRY,
TTY2_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
{NULL,NULL,NULL,NULL,NULL,NULL},
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
#include <confdefs.h>
rtems_id Task_id;
rtems_name Task_name;
const char* tty_ports [] =
"/dev/ttyS1",
"/dev/ttyS2"
rtems_task Test_task(
rtems_task_argument unused
FILE* fp = fopen (tty_ports [0], "r+");
if (!fp)
printf ("Unable to open %s", tty_ports [0]);
else
while (1)
if (!fputc('t', fp))
printf ("unable to write to port");
Init()
Task_name = rtems_build_name( 'T', 'A', '1', ' ' );
rtems_status_code status;
status = rtems_task_create(
Task_name, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES, &Task_id
status = rtems_task_start( &Task_id, Test_task, 1 );
"Correo Fernando-ruiz (E-mail)" wrote:
> > -----Mensaje original-----
> > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> > Enviado el: jueves, 28 de junio de 2001 3:52
> > Para: rtems-users
> > Asunto: Comm ports on Pc386
> > Does anyone have an example of using the comm ports on a PC386 build?
> Adding this like rtems device configuration you have
> THREE termios ports in your PC.
> /dev/console
> /dev/ttyS1
> /dev/ttyS2
> How to manage this ports with TERMIOS?
> See the /rtems/c/src/tests/libtests/termios directory.
> A complete program to drive a termios device.
> (My first source to understand it. Thanks Eric Norum)
> Enjoy it.
> Are you using the last snapshot (20010525)?
> With this you can open remote consoles in every port termios.
> /* TASK NAME,STACK SIZE, TASK PRIO, DEV_NAME, BAUDS & LINE SETT.,FOREVER*/
> #include <shell.h>
> Init() {
> shell_init("sh1",16384,100,"/dev/ttyS1" ,B38400|CS8,TRUE);
> shell_init("sh2",16384,100,"/dev/ttyS2" ,B38400|CS8,TRUE);
> shell_init("shc",16384,100,"/dev/console",B38400|CS8,TRUE);
> Three users accessing at same time at the PC but with RTEMS rtos.
> A new task for evevy user.
> Fernando RUIZ CASAS
> home: correo at fernando-ruiz.com
> work: fernando.ruiz at ctv.es
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > http://users.hunterlink.net.au/~maaaf/
> > There are those who seek knowledge for the sake of knowledge - that is
> > CURIOSITY
> > There are those who seek knowledge to be known by others - that is
> > VANITY
> > There are those who seek knowledge in order to serve - that is LOVE
> > Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
