Patch To avoid tcp/ip enabled in last snapshot (25052001)
Angelo Fraietta angelo at hunterlink.net.au
Tue Jul 3 23:27:47 UTC 2001
I have just successfully built the 386dx, so I would say there must have been
something wrong with my system yesterday. Sorry for the false alarm.
Angelo Fraietta wrote:
> The pc686 just built for me. I'll do some more tests to find out what is
> going on at my end.
> "Fernando RUIZ CASAS (E-mail)" wrote:
> > Hi Angelo.
> >  Yesterday. I have could rebuild in cygwin (In Linux no problem) all the
> >  tool chain including the last snapshot and build a new BSP pc686
> >  without problems (With the patch applied).
> >  What kind of problems have you?
> >  Rebuilding the BSP with
> >   make all install 2>errorfile
> >  you can capture the errors.
> > Fernando RUIZ CASAS
> > home:correo at fernando-ruiz.com
> > work:fernando.ruiz at ctv.es
> > > -----Mensaje original-----
> > > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> > > Enviado el: martes, 03 de julio de 2001 7:55
> > > Para: fernando.ruiz at ctv.es
> > > Asunto: Re: Patch To avoid tcp/ip enabled in last snapshot (25052001)
> > > I applied the patch, however, it appears that only the pc386
> > > is successfully being built. I get
> > > configure errors when I try to build pc386dx and pc686.
> > > > Hi rtems-users.
> > > > In order to build the last snapshot with tcp/ip disabled
> > > here a patch
> > > > moving the telnetd and pty to libnetworking directory.
> > > > This patch is already submitted to Joel.
> > > > But while the new snapshot arrives,a solution is here.
> > > > Sorry for the inconvenience.
> > > > Fernando RUIZ CASAS
> > > > De: Correo Fernando-ruiz (E-mail) [mailto:correo at fernando-ruiz.com]
> > > > Enviado el: lunes, 28 de mayo de 2001 8:49
> > > > Para: joel.sherrill at OARcorp.com; Fernando RUIZ CASAS
> > > (E-mail) (E-mail)
> > > > Asunto: RE: RTEMS SS-20010525 Available
> > > > In order to set up the last rtems snapshot this patch
> > > resolve the little
> > > > bugs
> > > > in the telnetd environment already discussed.
> > > > The psxchroot01 has been fixed.
> > > > Regards
> > > > Fernando RUIZ CASAS
> > > > home: correo at fernando-ruiz.com
> > > > work: fernando.ruiz at ctv.es
> > > > > De: joel [mailto:joel]En nombre de Joel Sherrill
> > > > > Enviado el: viernes, 25 de mayo de 2001 21:26
> > > > > Para: rtems-users at OARcorp.com; rtems-snapshots at OARcorp.com
> > > > > Asunto: RTEMS SS-20010525 Available
> > > > > In ftp.oarcorp.com /pub/rtems/snapshots/rtems/current.
> > > > > This snapshot includes improvements to the MIPS exception
> > > > > and interrupt processing, the Robominds MRM BSP, more
> > > > > configuration changes in the move to a BSP Kit, initial
> > > > > support for telnetd, improvements to the motorola BSPs,
> > > > > and some miscellaneous bug fixes.
> > > > > I have modified the script to generate bzip since they are
> > > > > about 40% smaller than gzip'ed images.  The script did not
> > > > > correctly generate the diff so I did it by hand.  I will
> > > > > get the script fixed before the next snapshot. :)
> > > > > Enjoy.
> > > > > Joel Sherrill, Ph.D.             Director of Research &
> > > Development
> > > > > joel at OARcorp.com                 On-Line Applications Research
> > > > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > > > >    Support Available             (256) 722-9985
> > > >                                        Name:
> > > rtems-ss-20010125.shell.diff.bz2
> > > >    rtems-ss-20010125.shell.diff.bz2    Type: Macintosh
> > > StuffIt Archive (application/x-stuffit)
> > > >                                    Encoding: base64
> > > Angelo Fraietta
> > > PO Box 859
> > > Hamilton NSW 2303
> > > Home Page
> > > http://users.hunterlink.net.au/~maaaf/
> > > There are those who seek knowledge for the sake of knowledge
> > > - that is CURIOSITY
> > > There are those who seek knowledge to be known by others -
> > > that is VANITY
> > > There are those who seek knowledge in order to serve - that is LOVE
> > >     Bernard of Clairvaux (1090 - 1153)
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> There are those who seek knowledge for the sake of knowledge - that is
> CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
