Comm ports on Pc386
Angelo Fraietta angelo at hunterlink.net.au
Wed Jul 4 22:45:22 UTC 2001
How do I change this? I thought that this was the
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
which is default as 20
Joel Sherrill wrote:
> Angelo Fraietta wrote:
> > I appears that the call to fopen should somehow make its way to tty1_open. I
> > do not believe that this is happening as I am not getting the fail message
> > from that call.  Tomorrow I will have a closer investigation and maybe place
> > some code in there to display whether it is getting there. Could it be that
> > the call to fopen requires some other configuration in order to map the
> > device driver to the filename?
> No it is likely that you do not have enough file descriptors allocated. The
> default is 3 (stdin, out, and error).
> > > Thank you for the help you have provided so far. I eventually got the
> > > program to build by adding
> > > #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> > > When I attempt to run the program, I get the message that /dev/ttsy1 & 2
> > > are initialised, however, I get the messages
> > > RTEMS: creating task sh1 in shell_init() (status: request not satisfied)
> > > I get a similar message for all three tasks.  Additionally, I spawned a
> > > task like the previous attempt, using  fopen ("/dev/ttys1"), however, this
> > > fails also.
> > > The code in its entirety is as follows:
> > > #define TEST_INIT
> > > #include <bsp.h>
> > > void test_main( void );
> > > rtems_task Init(
> > >   rtems_task_argument ignored
> > >   test_main();
> > > /* configuration information */
> > > #include <rtems.h>
> > > #include <tty_drv.h>
> > > #include <console.h>
> > > #include <clockdrv.h>
> > > #include <timerdrv.h>
> > > #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > > #define CONFIGURE_MAXIMUM_TASKS             6
> > > rtems_driver_address_table Device_drivers[] = {
> > >         CONSOLE_DRIVER_TABLE_ENTRY,
> > >         TTY1_DRIVER_TABLE_ENTRY,
> > >         TTY2_DRIVER_TABLE_ENTRY,
> > >         CLOCK_DRIVER_TABLE_ENTRY,
> > >         {NULL,NULL,NULL,NULL,NULL,NULL},
> > > /*#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER*/
> > > #define CONFIGURE_INIT
> > > #include <confdefs.h>
> > > #include <stdio.h>
> > > rtems_id   Task_id;
> > > rtems_name Task_name;
> > > rtems_task Test_task( rtems_task_argument unused);
> > > void test_main()
> > >   rtems_status_code status;
> > >   Task_name = rtems_build_name( 'T', 'A', '1', ' ' );
> > >   status = rtems_task_create(
> > >     Task_name, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
> > >     RTEMS_DEFAULT_ATTRIBUTES, &Task_id
> > >   status = rtems_task_start( Task_id, Test_task, 1 );
> > > shell_init("sh1",16384,100,"/dev/ttyS1"  ,B9600|CS8,TRUE);
> > > shell_init("sh2",16384,100,"/dev/ttyS2"  ,B9600|CS8,TRUE);
> > > shell_init("shc",16384,100,"/dev/console",B9600|CS8,TRUE);
> > > const char* tty_ports [] =
> > >  "/dev/ttyS1",
> > >  "/dev/ttyS2"
> > >  FILE* fp = fopen (tty_ports [0], "r+");
> > >  if (!fp)
> > >    printf ("Unable to open %s", tty_ports [0]);
> > >  else
> > >    while (1)
> > >      if (!fputc('t', fp))
> > >        printf ("unable to write to port");
> > > "Fernando RUIZ CASAS (E-mail)" wrote:
> > >> Hi
> > >> If you want to use shell_init without tpc/ip enabled I can send to you
> > >> the patch already submitted to Joel.(05/26/01)
> > >> I have not made none modification in the pc386 BSP code to enable
> > >> the ports. Only this code has been used.
> > >> In shell_init only a make raw mode TERMIOS is done
> > >> (How the linux man page says)
> > >> None error is showed in the compilation of pc386(pc686) bsp.
> > >> Browse in the sources and ask directely to Eric, Rosimildo & more about
> > >> the
> > >> use of this. (The authors of little patchs...)
> > >> I have use this ports like a linux device using only TERMIOS programming.
> > >> And this works successfully.
> > >> Your code seems correct. I Can try it.
> > >> Fernando RUIZ CASAS
> > >> home:correo at fernando-ruiz.com
> > >> work:fernando.ruiz at ctv.es
> > >> > -----Mensaje original-----
> > >> > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> > >> > Enviado el: lunes, 02 de julio de 2001 3:38
> > >> > Para: correo at fernando-ruiz.com
> > >> > CC: Rtems-Users (E-mail)
> > >> > Asunto: Re: Comm ports on Pc386
> > >> > I am using the previous snapshot as  do not have networking
> > >> > enabled. I am
> > >> > trying to open the commport and write some chars (for now).
> > >> > If I just try to
> > >> > open the port without the code you provided, the file does
> > >> > not open. I assume
> > >> > it is because the port has to be configured with the code you
> > >> > provided.
> > >> > However, trying to compile this below, I get a heap of parse errors in
> > >> > ttr_drv.h.
> > >> > Is this because of the snapshot or am I doing something wrong here?
> > >> > #define CONFIGURE_MAXIMUM_TASKS             1
> > >> > rtems_id   Task_id;
> > >> >  "/dev/ttyS1",
> > >> >  "/dev/ttyS2"
> > >> >  if (!fp)
> > >> >  else
> > >> >    while (1)
> > >> > Init()
> > >> >   status = rtems_task_start( &Task_id, Test_task, 1 );
> > >> > > > Enviado el: jueves, 28 de junio de 2001 3:52
> > >> > > > Para: rtems-users
> > >> > > > Asunto: Comm ports on Pc386
> > >> > > > Does anyone have an example of using the comm ports on a
> > >> > PC386 build?
> > >> > > Adding this like rtems device configuration you have
> > >> > > THREE termios ports in your PC.
> > >> > > /dev/console
> > >> > > /dev/ttyS1
> > >> > > /dev/ttyS2
> > >> > > How to manage this ports with TERMIOS?
> > >> > > See the /rtems/c/src/tests/libtests/termios directory.
> > >> > > A complete program to drive a termios device.
> > >> > > (My first source to understand it. Thanks Eric Norum)
> > >> > > Enjoy it.
> > >> > > Are you using the last snapshot (20010525)?
> > >> > > With this you can open remote consoles in every port termios.
> > >> > > /* TASK NAME,STACK SIZE, TASK PRIO, DEV_NAME, BAUDS & LINE
> > >> > SETT.,FOREVER*/
> > >> > > #include <shell.h>
> > >> > > Init() {
> > >> > > shell_init("sh1",16384,100,"/dev/ttyS1"  ,B38400|CS8,TRUE);
> > >> > > shell_init("sh2",16384,100,"/dev/ttyS2"  ,B38400|CS8,TRUE);
> > >> > > shell_init("shc",16384,100,"/dev/console",B38400|CS8,TRUE);
> > >> > > Three users accessing at same time at the PC but with RTEMS rtos.
> > >> > > A new task for evevy user.
> > >> > > Fernando RUIZ CASAS
> > >> > > home: correo at fernando-ruiz.com
> > >> > > work: fernando.ruiz at ctv.es
> > >> > > > Angelo Fraietta
> > >> > > > PO Box 859
> > >> > > > Hamilton NSW 2303
> > >> > > > Home Page
> > >> > > > http://users.hunterlink.net.au/~maaaf/
> > >> > > > There are those who seek knowledge for the sake of
> > >> > knowledge - that is
> > >> > > > CURIOSITY
> > >> > > > There are those who seek knowledge to be known by others - that is
> > >> > > > VANITY
> > >> > > > There are those who seek knowledge in order to serve -
> > >> > that is LOVE
> > >> > > >     Bernard of Clairvaux (1090 - 1153)
> > >> > Angelo Fraietta
> > >> > PO Box 859
> > >> > Hamilton NSW 2303
> > >> > Home Page
> > >> > There are those who seek knowledge for the sake of knowledge - that is
> > >> > CURIOSITY
> > >> > that is VANITY
> > >> > There are those who seek knowledge in order to serve - that is LOVE
> > > Angelo Fraietta
> > > PO Box 859
> > > Hamilton NSW 2303
> > > Home Page
> > > CURIOSITY
> > > There are those who seek knowledge to be known by others - that is VANITY
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > CURIOSITY
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
