Using termios/stdio to check for characters
Correo Fernando-ruiz (E-mail) correo at fernando-ruiz.com
Wed Jul 11 16:51:19 UTC 2001
> -----Mensaje original-----
> De: OUTWATER ~ KEITH J /5G3110 [mailto:vac4050 at tueng.rsc.raytheon.com]
> Enviado el: miercoles, 11 de julio de 2001 18:23
> Para: rtems-users at oarcorp.com
> Asunto: Using termios/stdio to check for characters
> Greeings all -
> Does anyone know of a way to check a stream to see if
> characters are available
> for input using termios and/or stdio?
Setting NONBLOCK read the filedes and read() returning 0 bytes readed.
But this a poor solution.
You need set the ioserial driver with an event for reception
and rtems_waitevent(RTMS_EVENT_X,ticstimeout);
Do you want more information about a rtems_serial_driver for a 14550 UART?
I can help you if you want.
> Basically, I want to perform a non-blocking check on the
> console port for
> received characters.
> Thanks,
> keith
