termios wakeup callback functions
Mike Siers
mikes at poliac.com
Wed Jul 11 18:45:48 UTC 2001
Hi,
The attached patch file will provide the ability to specify some
wakeup callback functions for termios. Basically, this defines
a ttywakeup structure that is similar to the socket wakeup
structure. The tty wakeup structures are set by using the
ioctl function.
Basically, you use the RTEMS_IO_RCVWAKEUP or
RTEMS_IO_SNDWAKEUP ioctl commands and pass in an
address to a ttywakeup structure. The wakeup functions are
called if data has been received on a tty or if the send buffer
has become empty on the tty.
The patch file was created from the 2001/05/25 snapshot.
Good Luck
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010711/bd6f78ff/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010711/bd6f78ff/attachment.obj>
