bsd network and C++
Rosimildo da Silva
rdasilva at connecttel.com
Sun Jul 15 11:10:11 UTC 2001
From: "Rosimildo da Silva" <rdasilva at connecttel.com>
To: "Peter Müller" <peter.o.mueller at gmx.de>; "rtems"
<rtems-users at oarcorp.com>
Sent: Sunday, July 15, 2001 5:49 AM
Subject: Re: bsd network and C++
> From: "Peter Müller" <peter.o.mueller at gmx.de>
> To: "rtems" <rtems-users at oarcorp.com>; "Rosimildo da Silva"
> Sent: Saturday, June 30, 2001 1:52 PM
> > > Rosimildo.
> > Here is my test code. Would be great if you could test it.
> > Peter
> Peter, sorry for the delay. Only today I could get a hold and check this.
> I had some problems with this demo. :-)
> 1. Stack of the secondary task would blow up. 1K size -- change it to
> 16K
> 2. I get an error 13 ( request not safisfied ) on task1->create(). And
> error 23( not owner )
> on task1->start()
> I did not bother to find out what is wrong. I guess the default config on
> PC386 is not
> the same as m68K, and something is making the creation of the task to
fail.
> The point is, this demo also fails here.
> Rosimildo.
Peter, I decided to switch to the configuration that I usually
use, and everything worked fine.
I've attached the system.h that I used. The resources a bit exagerated. :-)
Rosimildo.
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010715/be23912a/attachment.obj>
