Consider the following code in chain.c:
void _Chain_Append(
Chain_Control *the_chain,
Chain_Node *node
ISR_Level level;
_ISR_Disable( level );
_Chain_Append_unprotected( the_chain, node );
_ISR_Enable( level );
The parameter level has no initial value when _ISR_Disable is called.
Rong
