the parameter has no initial value before reference
Gerwin Pfab pb at schenk.isar.de
Tue Jul 17 07:20:12 UTC 2001
carerie,
_ISR_Disable( level) is a makro. level is an output parameter and gets the
value inside _ISR_Disable().
Gerwin Pfab
Gerwin Pfab <pb at schenk.isar.de>   Dr. Schenk Industriemesstechnik GmbH
Dipl. Ing.                        Einsteinstrasse 37
Software Engineering              D-82152 Martinsried
                                  Tel: +49-89-85695-0
                                  Fax: +49-89-85695-200
On Tue, 17 Jul 2001, careri/sed wrote:
> Consider the following code in chain.c:
> void _Chain_Append(
>   Chain_Control *the_chain,
>   Chain_Node    *node
>   ISR_Level level;
>   _ISR_Disable( level );
>     _Chain_Append_unprotected( the_chain, node );
>   _ISR_Enable( level );
> The parameter level has no initial value when _ISR_Disable is called.
> Rong
