SEVERE Bug in mc68360 _ISR_Handler???
Tue Jul 17 22:48:17 UTC 2001
Thomas Doerfler wrote:
> Hi Bob,
> > Greetings from the UK.
> > I remember there was an interrupt problem with the '360 that we came across
> > when we were trying to test the TCP stack about 9 months ago. All I can
> > remember is that to fix it, the "tick" timer had to be on the same (or
> > lower?) interrupt priority than the network to prevent the very occasional
> > scc lockup. At the time Joel and Eric couldn't see what was going wrong -
> > and as far as I know it was never tracked down - it was well beyond my
> > capability!. I believe there is a comment in a "readme" file enclosed with
> > the current 68360 distribution explaining the workaround.
> > Am I off track here or could this be the same problem resurfacing?
> No you are right, putting the PIT to a lower level also works ok. I
> am really glad to here that I am not the only one who saw that
> problem.
> I think it is very '360 specific, because all CPM interrupts get
> masked as soon as the CPU has fetched the interrupt vector (oposed to
> many other interrupt sources that remove the interrupt request only
> when the actual peripheral register are accessed).
No.  I think it is not 68360 specific just made worse and more
frequent on the 360 since it is typically a heavy IRQ handler.
I think this is Bob Wisdom's problem resurfaced.  Just this time
in a more obvious way to handle.
And Chris' comment about needing to check for "ISR_Handler" being
the return address on all m68ks without separate stacks except
68060 and Coldfire is more than likely on the money.
Summary analysis:
Some m68k models do not guarantee that the first instruction in
an ISR will be executed if a higher priority interrupt occurs.
m68ks with separate stacks have a dedicated in HW interrupt stack
and push a special F/VO stack frame on the outer most interrupt to
indicate that you are at the edge of the interrupt stack and
that the rte popping this F/VO must switch the the other
(always master for RTEMS) stack.
"m68ks without separate stacks" is all m68k's based on
68000, cpu32, and coldfire cores.  Quote from Chris Johns:
  Also, Motorola fixed the '060 and Coldfire's by allowing the first
  instruction after the interrupt to execute before allowing the core to
  service another interrupt
The 68020/30/40 have a throwaway F/VO stack frame so we always know we
are nested in a hardware defined manner.  No problem on those models.
Even if the interrupt occurs before the 1st instruction, the throwaway
for the outermost interrupt is still there so all is cool.
The other CPU models do not have a HW interrupt stack, thus do not
switch
stacks, and thus do not generate the throwaway stack frame.  They
can nest to the 2nd interrupt before processing ANYTHING of the FIRST.
Chris's patch inserts the equivalent of the F/VO logic for these
CPU models.
Size of window:
  + 1st interrupt occurs
  + CPU pushes interrupt stack frame
     !!NO CODE FROM 1ST INTERRUPT EXECUTES!!!
  + 2nd interrupt occurs
  + 2nd interrupt of higher priority occurs
  + 2nd priority interrupt executes
The size of the window is the time required to push an interrupt
stack frame on some m68k CPU models.  This should be 680x0 and
683xx primarily since they use CPU32, CPU32+ and 68000 cores.
Let's give Thomas a while to test this.
Bob .. if you changed your interrupt priorities back, could you
reproduce the same failure you used to get?
> Bye,
>         Thomas.
> > Bob Wisdom
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-systems.de/pgp_key.htm
