SEVERE Bug in mc68360 _ISR_Handler???
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Wed Jul 18 13:33:08 UTC 2001
Hello,
> Chris could you repost it to the list.  Eric Norum and I wondered
> if the logic to enable it should be something like:
> HAS_SEPARATE_STACKS==0 && COLDFIRE==0 && 060==0
I think, Chris has already found the proper condition:
#if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == 1 )
  #if ( M68K_COLDFIRE_ARCH == 0 )
So, Chris, I would keep the patch exactly as you sent it to me...
Bye,
	Thomas.
> I will then put this in the 4.5 branch, mainline, and
> in a patches directory on the ftp server.
> --joel
> > Bye,
> >         Thomas.
> > > Thomas Doerfler wrote:
> > > > I will hack that into my test software and then make my network heat
> > > > up again to blow hard against my poor RTEMS system :-)) . No need to
> > > > publish it before it acutally works.
> > > Try the attached patch. It is only 2 extra instructions :-)
> > >  Chris Johns, cjohns @ cybertec.com.au
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler           Herbststrasse 8
> > D-82178 Puchheim          Germany
> > email:    Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-systems.de/pgp_key.htm
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
