i386 Serial Driver Problem
Angelo Fraietta angelo at hunterlink.net.au
Mon Jul 23 01:53:53 UTC 2001
I tested this out and this was not my problem. I found out through
exhaustive
experimentation that when my terminal received the char 0x13, it stopped
sending anything else out of the comm port.
I subsequently fixed the problem by adding the following to my port
configuration after opening it:
ts.c_iflag &= ~(IXON | IXOFF | IXANY);
Mike Siers wrote:
> Hi Angelo,
> This change was made in the following file:
>   lib/libbsp/i386/shared/comm/tty_drv.c
> Search for the functions tty1_last_close and tty2_last_close
> and remove them from the termios callback structures.
> Good Luck
> Mike Siers
> -----Original Message-----
> From: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> Sent: Thursday, July 19, 2001 8:54 PM
> To: Mike Siers
> Cc: Thomas Doerfler; rtems-users at oarcorp.com
> Subject: Re: i386 Serial Driver Problem
> Where did you do this? In termios.c?
> Mike Siers wrote:
> > Hi Thomas,
> > Thanks for the hint.  I solved this problem by making
> > two sets of changes.
> >   1) The i386 driver callbacks were set up to call
> >      the lastClose callback function.  This function
> >      removed the IRQ handler for the serial port.  I just
> >      set the callback function to NULL.
> >   2) The pppd code had a resource leak.  It was opening up
> >      a socket handle that was not getting closed and was
> >      causing some problems.  I have this fixed in my updated
> >      version of pppd.  I have successfully open/closed a ppp
> >      connection over a null modem serial cable 600 times
> >      without a problem.
> > Thanks
> > Mike Siers
> > > From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> > > Sent: Friday, July 13, 2001 9:16 AM
> > > To: Mike Siers
> > > Hi Mike,
> > > I have the same behaviour with my MC68360 driver. I had invested some
> > > hours to find out about the problem but dropped it (due to more
> > > urgent things). I had stepped into the LCP layer state machines, and
> > > it seemed to me that they don't want to actively establish a
> > > connection, if the first tries have not succeeded. Nevertheless it
> > > was possible to request a connection from outside...
> > > I wouldn't blame the driver for this behaviour. Possibly it has to do
> > > with PPP configuration (better pseudo-script???) or with the fact,
> > > that PPP internal global variables are not reinitialized when PPP
> > > restarts...
> > > Bye,
> > >       Thomas.
> > > > Hi,
> > > > I have an application that is trying to establish a ppp connection
> > > > on a serial port.  The application can bring up a ppp connection
> > > > right after the PC has been rebooted.  However, any other attempts
> > > > after this initial ppp connection fail.  All the termios functions
> seem
> > > > to be functioning but it looks like no data is being sent out the
> > > > serial port.  I am using the task driven serial driver.
> > > > Has anyone else had a similar problem with the i386 serial driver?
> > > > Any thoughts or information would be greatly appreciated.
> > > > Thanks
> > > > Mike Siers
> > > IMD Ingenieurbuero fuer Microcomputertechnik
> > > Thomas Doerfler           Herbststrasse 8
> > > D-82178 Puchheim          Germany
> > > email:    Thomas.Doerfler at imd-systems.de
> > > PGP public key available at: http://www.imd-systems.de/pgp_key.htm
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://users.hunterlink.net.au/~maaaf/
> There are those who seek knowledge for the sake of knowledge - that is
> CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
VANITY
