i386/pc386 COM2 Serial Port Problem
Angelo Fraietta
angelo at hunterlink.net.au
Tue Jul 24 01:07:06 UTC 2001
Have you tried increasing the number of file descriptors 20?
Mike Siers wrote:
> Hi,I have program that works perfectly when I use the COM1 serial
> port.If I switch the application to use COM2 instead of COM1, it does
> notwork. It does not look like any data gets transmitted out over the
> port. I have both the tty drivers in my device driver table and I see
> the deviceinitialized message for both COM ports. I also have the
> number offile descriptors set to 8.Has anyone seen this problem? My
> application requires that I use bothCOM ports. This test application
> is only using one port at a time but it does not work with COM2. I am
> using the latest snapshot 2001/07/12.ThanksMike Siers
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://users.hunterlink.net.au/~maaaf/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is
VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20010724/ffe9519e/attachment.html>
