PPPD Update
Mike Siers
mikes at poliac.com
Fri Jul 27 15:23:28 UTC 2001
Hi,
Here is an updated version of the pppd code. Follow the same install
instructions. Below is a list of issues that I fixed.
- i386 COM2 uart driver problem
- added option reset function and removed initialization code from main
- fixed problem with the "defaultroute" option
Please try it out and let me know what you think.
Thanks
Mike Siers
-----Original Message-----
Sent: Monday, July 23, 2001 3:00 PM
To: rtems-users at oarcorp.com
Subject: PPPD Update
Hi,
The attached files provide a fresh port of pppd 2.3.11 for RTEMS.
I have done all my testing with the i386/pc586 BSP.
Please try it out. I would like to get these changes merged into
the next snapshot.
Installation:
1) Apply patch file to snapshot 2001/07/12
(if using i386, you also need to update tty_drv.c to use task driven
I/O)
2) Rename the c/src/libnetworking/pppd directory
3) Untar the new pppd code into the c/src/libnetworking directory
4) Rebuild RTEMS
5) Check out the new example program in c/src/libnetworking/pppd/example
Thanks
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010727/b328a86f/attachment.html>
Type: application/x-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010727/b328a86f/attachment.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010727/b328a86f/attachment.obj>
