Problems with starting new BSP
Radzislaw Galler
morib at morib.com.pl
Wed Jul 4 15:42:53 UTC 2001
On Tuesday 03 July 2001 12:11, Joel Sherrill wrote:
> When you say "reenabling interrupts", do you mean all potential interrupt
> sources? My gut instinct says that you have an uninitialized interrupt
> source that is happening. Do you have a spurious interrupt handler in
> your BSP to report an unexpected interrupt?
> I don't know if there is a generic sh spurious interrupt handler like
> there is for some other CPUs. I think the m68k has a nice example of
> one.
After I twiddled a bit with interrupts trying to catch the spurious ones the
system started to work, but I don't know what helped, because when I tried to
get back to the previous state (using old files) the system also worked.
It could be that I lost couple of days seeking a nonexistent bug which only
needed to touch sources and recompile the libraries :)
Anyway right now I'm quite suspicious about #pragma interrupt directive
(although it works now).
Thanks
Radek
