new gcc and binutils RPMS was Re: Problems with arm-rtems-gcc
Thu Jul 12 16:28:46 UTC 2001
I had actually just put them on the ftp site.  There are
new RPMS for:
  binutils 2.11.2
  gcc 2.95.3+newlib 1.9.0
NOTE: binutils 2.11.2 still seems to be broken for sh-coff. We are
      locally still using the last binutils 2.10 RPMs and those were
      used to build the new gcc RPMS.
Please report problems to the list.
--joel
"wangyf(sina)" wrote:
> But where can I get gcc 2.95.3 for rtems? Can I use arm-linux-gcc to compile RTEMS?
> Best regards,
> yunfei
> ----- Original Message -----
> From: "Marc Salem" <msalem at cse.unsw.edu.au>
> To: "wangyf(sina)" <wangyf_tshua at sina.com>
> Cc: <rtems-users at oarcorp.com>
> Sent: Thursday, July 12, 2001 4:20 AM
> Subject: Re: Problems with arm-rtems-gcc
> > On Wed, Jul 11, 2001 at 09:16:06PM +0800, wangyf(sina) wrote:
> > > Hi, Dear all,
> > > I have download arm-rtems-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm from ftp.oarcorp.com and install it. I can build RTEMS with it, but it cannot accept "-fpack-struct" option. If I type " arm-rtems-gcc ... -fpack-struct ... ", there is no error happening, but the structures in my program will not be packed.
> > > Has anyone met such a problem before? Please comment.
> > > Thanks!
> > I had problems using arm-linux-gcc 2.95.2 in another project. At the
> > very least, it generates incorrect code when it optimises 32-bit
> > constant loading/generation.
> > This is where it replaced a 32 bit load of a constant from memory with
> > two instructions to build it using immediates. My assumption was that
> > the machine description for some ARM instructions was incorrect.
> > arm gcc 2.95.3 is working fine for me.
> >  -Marc
> > > Best regards,
> > > Yunfei Wang
> > Marc Salem
> > m.salem at unsw.edu.au
> > 0416 033 180
> > UNSW Solar Racing Team          School Of Computer Science & Engineering
> > http://www.sunswift.com/        http://www.cse.unsw.edu.au/
