using rtems_message_queue_send in interrupt context
suvrat gupta
suvrat at utstar.com
Tue Jul 31 19:55:05 UTC 2001
Hi,
RTEMS documentation says that its okay to use rtems_message_queue_send in
interrupt context.
The file coremsgsubmit.c seem to have a problem:
void _CORE_message_queue_Submit(
CORE_message_queue_Control *the_message_queue,
void *buffer,
unsigned32 size,
Objects_Id id,
CORE_message_queue_API_mp_support_callout api_message_queue_mp_support,
CORE_message_queue_Submit_types submit_type,
boolean wait,
Watchdog_Interval timeout
ISR_Level level;
CORE_message_queue_Buffer_control *the_message;
Thread_Control *the_thread;
Thread_Control *executing;
_Thread_Executing->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL;
What does _Thread_Executing points to when this function is called form an
interrupt context?
If this point to the task which was interrupted when an interrupt occurred
then we will update the return value for that task too!
According to us you cannot use send to message queue function in both task and
interrupt context at the same time.
Am I missing something here? Is this a known problem? Or do I have old
documentation.I am working on 4.5.0
thanks
-suvrat
