shell question
Tue Jun 5 14:19:24 UTC 2001
Eric Norum wrote:
> OUTWATER ~ KEITH J /5G3110 wrote:
> > Fernando -
> > Thanks for the info.
> > I'm currently registering lots of additional commands with the RTEMS monitor
> > using the RTEMS monotor's command entry type.
> > Are you saying that once I've registered the additional commands with the RTEMS
> > monitor that they are automatically availble in the shell?
> > Also, It would be nice to have command completion (may be the ability to type in
> > partial commands or some typ ef auto-completion)
> Does this command interpreter use readline?  If so, command completion
> wouldn't be hard to add and command-line editing and history is provided
> automatically.  If not, why not?  I suppose the big problem would be
> that readline isn't thread-safe :-(
And AFAIK is pure GPL.
> Eric Norum                                 eric.norum at usask.ca
> Department of Electrical Engineering       Phone: (306) 966-5394
> University of Saskatchewan                 FAX:   (306) 966-5407
> Saskatoon, Canada.
