GCC-2.95.3
Wed Jun 6 23:56:31 UTC 2001
Angelo Fraietta wrote:
> I think that the best way to approach the situation is to use the pre-built rpm.  You would not have to backup your old gcc at all
That's the best approach.
But you should also be able to take the gcc 2.95.2 source RPMs and
with slight modifications build a 2.95.3 set for yourself.  The
patch should be OK.
> John Lowen wrote:
> > I am new to RTEMS and am just beginning an evaluation of the OS. I am comfortable with building GNU tool chains and have a simple question. I am using gcc-2.95.3. Are the rtems patches for gcc-2.95.2 ok to use with gcc-2.95.3 or will I have to back up and build gcc-2.95.2?
> > Thanks,
> > John
> > AMT-Datasouth
> > jlowen at amtdatasouth.com
> > http://www.datasouth.com
> > (704)523-8500 ext. 132
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://users.hunterlink.net.au/~maaaf/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
