bsdnet attach
Fri Jun 8 12:44:06 UTC 2001
peter.o.mueller at gmx.de wrote:
> Hi,
> building some network code I found that the attach function required in
> rtems_bsdnet_ifconfig has a 2nd parameter.  But in the rtems_bsdnet.h file
> the prototype for rtems_bsdnet_attach does not have this 2nd parameter. I
> think this function is not intended for use in the struct. More confusing is
> that the attach function for the loopback does not have the 2nd parameter
> too.
> void
> rtems_bsdnet_loopattach(dummy)
>         void *dummy;
> Can anybody bring some light into this?
The parameter was added and not everything was consistently updated.
The
send parameter is an attach/detach flag.
> Thank you,
> Peter
> Machen Sie Ihr Hobby zu Geld bei unserem Partner 1&1!
> http://profiseller.de/info/index.php3?ac=OM.PS.PS003K00596T0409a
> GMX - Die Kommunikationsplattform im Internet.
> http://www.gmx.net
